Factory Service Manual Worth It Over Haynes ?
21 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
factory service manual runs around $150 shipped. Is it worth it over the haynes manual ? Is it much more descriptive and go into more detail ?
factory, you get 7 large manuals weighing 39 pounds. no compairson
Factory shop manual cannot be compared to a Hayes manual. If you are going to be seriously working on your truck, then you should get the factory shop manual. If you just want to know where something is, Hayes will do fine.
have you ever tried to use a hayes? Half the the jobs you will tell you to use the "recomended torque". thats usefull. FSM is the way too go. esp if you ever have an electrical problem
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 857 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
