i was just looking at my truck outside and noticed that one wheel is leaning alot and i looked at the tire wear and the inside of the tire is almost baled. any idea how much a wheel alignment cost? can post pics if needed
roughly 90 bucks for 4x4...i think 70 bucks for 4x2...those are for the front only as the rear probably won't need it
ya the back looks ok but the front passanger is way out at the botton i guess that camber maybe i should just post a pic
generally the rear axle dosen't ever need to be aligned unless you fish tail into a curb or somethen
I have argued this point many times with shops. GM has a wierd spec that actually requires one side to be aligned different than the other, not just on the Full size but also on the Midsize trucks. Most shops will set them the same and not pay attention to the GM specs. Look next time you have one done, I believe it is the passenger side. They need to stick with GM specs wierd but true.
ya its weird cuz i didnt hit anything but theres alot potholes up here
also no mods....... yet
It could have came that way from GM. My Camaro SS's was off from the factory and was unknown to me until like you I noticed abnormal tire wear.
The alignment was out on my 09 Silverado from the factory also. I noticed significant feathering the first time I rotated the tires so I went ahead and had an alignment done.
Some shops offer "Life Time" alignments for the life of your car/truck. Firestone offers them in my area and should have the same in yours. Cost is $180 but you can take it in when every you want. I try to take mine in every 3 months or so. And the left if always off. So it's something to think about.
  • 3 weeks later...
maybe if i would have went to the dealer but i hate them and they always fine other sh^t thats "needs" to be fixed lol but it cost me 85.00 at midas
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 765 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
