Stock Cd Player
Hey guys this is my first post and to bad it has to be with a problem. I just recently purched a 2007 GMC Sierra MAX from a reputable used car lot out of LA. Everything about this truck has been great except for one problem i have found (besides the 6.0 :D ) I went to pop my First CD into the CD player and after 30 sec of it trying to read it, the screen then said "Disc Error" so i figured ok a burnt disc maybe i messed up burning it. SO I then went and grabbed a normal un burned true legit CD and popped it ASSUMING it would work but again after 30 sec i saw a "Optical Error" message. I then tried one last time with a different original copy legit CD (heart beating nervously) and failed again seeing a "Disc Error" message.
So now I don't know what to do. my truck came from the factory with a DVD player/CD player(two different drives), and my DVD Drive is doing all the work right now luckily. Any one have this same problem?? I'm I SOL??. what should i do?? I REFUSE to get a aftermarket unit b/c i love the stock one.
Thanks in advance.
I hope it works out, I would hate to go after market too.
Its probably hooped.
I havent gotten a reply yet so i hope there is something i can do before having to get a new one from GM. Hooped what does that mean??
It may be a shot in the dark, but if the dealer you got your truck from is as reputable as you say, I'd go back to him and see if he will help you out. It may be that there's dirt on the optical and just needs to be cleaned. Either way, I'd at least contact them and see what they say.
thanks redsled. I'm going to them a call this in the next day or so. just don't know if its worth the drive in gas all the way to LA as I live in SoCal specifically Santee/ El Cajon Area.
They make cd drive cleaning discs they are just like a normal cd but have a little brush on the bottom for cleaningany dust and debris from inside your drive. You used to be able to find them pretty much everywhere like walmart, radioshack,target so I would give one ofthem a shot I haveused them a few times and they work wonders.
Im probably the bearer of bad news but im on my 5th stock radio in my 09. The last one put in has been good but after the fourth and complaining thru GM costumer service they put the 6 disk changer in and i have it logged in that work done that if that one fails, they will put the nav unit in. Also warranted the radio to 100K.
So f I'm understanding as a last resort GM will Replace it??? if so for how much?? should i even bother calling the dealer from which i bought the truck, or do i just go to a GM Dealer. Sorry for all the question, but music is a very big part of my driving experience.
My guess is that his 09 was/is still covered under bumper to bumper warranty. You can purchase a new head unit but they are not the cheapest. I just replaced my single disc to the 6 disc changer. Contacting GM most likely won't do any good. Try cleaning the H/U with a cleaning cd or contact the dealer where you bought it.
Hey guys, a little update i tried the CD with the small little brushes on it and after seeing two screens that said "Disc Error" and another two that said "Optical Error"(the cleaning disk didn't play like it did in my DVD drive). I think i have come to the conclusion that the drive is bad and needs to be replace. What are some of my options? Kinda stated to look around and found this http://www.scosche.com/car-audio/product/1679. But I'm confused is this the whole in dash unit or just the blue tooth thing. Will this cancel my DVD drive to?? Any other opinions are MORE then welcome.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 403 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
