Looking For Ideas On Vibration
i just had a 6,, rough country lift kit with 35x13.50 r 18 dick cepek fc11 tires and also rancho my ride shocks put on my 2008 chevy hd 2500 and at about 65 mph there is a tight vibration that is somewhere in the front becouse i can feel it in the stearing wheel and in the gas peddle...no matter what i do its there untill i slow down below 65...strangest dang thing ...so i thought it was in the tires becouse they were out of round so i sent them back and ordered some mickey thompson baha atz,s...i would like to get this problem fixed before i get the new tires ....wich seem to be takin forever...they have been on backorder for three weeks now ..figures any way they say they will ship them out this monday so i got to figure this out pretty quick ...could it be in the lift somewhere ?....im at a loss any help would be great
Did you put aftermarket wheels on? If yes, make sure they removed the clips off of the rear wheel studs. Believe it or not, those little clips can cause major vibrations and alot of tire guys forget to take them off when putting on new wheels. Also make sure that your truck is in 2wd and not Auto 4x4 if you're 4wd.
plus one on the wheel clips those things cause massive issues. if not, it could be the wheels. could be worn out steering components in the front also. and ive never had good luck balancing those dick cepek tires....
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,207 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
