Gremlins
OK, two mornings in a row the truck wouldn't start with the remote start. Yesterday it didn't I got it turned the key, not even a noise to try starting? After a few tries nothing. I thought maybe because I shut the truck off in 4 high, so I turned the key to on and put the transfer case in 2, still nothing when turning the key until about the third time and magically started right up. Service 4wd light came on then a couple minutes later went off, and on the way home from work service trailer brake came on then off. All good until this morning, same thing exactly, except now on my way into work I go to turn on the high beams and the interior blue dash indicator lit up but no high beams outside.... -20C yesterday, -03C today. Certainly can't be the temperature outside, but something is amuk. I'm due for an oil change next week 10,000Km, but I really doubt the dealer will find anything just by checking codes, but if anyone has any ideas on where to point to them I'm all ears.
Extremely dissapointing at less than 10,000km I'm having electrical gremlins. I've not checked any fuses yet, I'm just too damn mad to do anything right now. My 04 never had any issues.
Thanks in advance for any thoughts on this.
An appointment with the dealer would be in order....... let them check it out - you have warranty.
Cheers
O.K. Very disturbing. I booked an oil change/gremlin finding appt at the dealer for tuesday. Came home from work today and because the high beams were not working thought I'll check fuses under the hood. :-(. Hot the heck did it have ice and water around the outer channel and into some of the fuses and crank/run relay? Copper blue corrosion, white residue from other fuses and relays? Bizarre.... I've never taken the cover off before, never off road, never washed the engine, nothing. Why is the ice and water inthere f&$@&$ with my new truck? Poor fitting cover? I have no idea. I was pleased to see on this truck vs. My 04 there are release levers on both ends to remove the fuse/relay board, because I called the dealer back to tell them what I'm looking at and that I want the whole board and rusty fuse, relay, connection replaced. I am in awe. No cracks on the cover and all 4 tabs were inlock position WTF? I can't begin to explain it even being possible....
If you've got Gremlins in your truck....
no wonder you're having problems.
:shakehead: jk
Seriously, good luck with getting everything fixed.
    Brendan C
    Brendan C
  • Who's Online   1 Member, 0 Anonymous, 1,222 Guests (See full list)
