"the Black Tie Event"
kdrchuck
I did the debadge a week or 2 ago, took the stickers off today. Cleaned the truck up nice so I figured i would take a few pics.
I think they turned out pretty good except for the drip from the mirror.
Feel free to critique the photos or the truck. I plan on debadging the doors and removing the body moldings. I am waiting untill i get a polisher. The paint actually has quite a few swirls that I plan on correcting.
I was also thinking about tinting the tail lights a little (not dark). but they dont really bother me since i got the stickers off.
I used fishing line and 3M adhesive remover (which I do not like) on the badges. Hair dryer on low and 3m stuff on the stickers. The hair dryer works great and feels really safe. I am gonna try Goo Gone on the rest. I cleaned everything up with some Meg's Ultimate Compound and Auto Glym SRP. then coverred one side in NXT and the other in Gold class. I like the NXT much better.
Still on the agenda:
Window tint
Nice chrome wheels (offset a little wider)
Magnaflow
Line-X
Hitch
And Several hours of paint correction.
Let me know what you think!
Looks Great. How did you remove the rear bowite? Is it bolted on or stuck on with an adhesive. Wanting to remove mine... just unsure how to do it correctly.
The badges just stuck on and come off easy wish fishing line, flossing them off. There are a few threads on it. Used my fingernails and 3M adhesive remover to get the tape residue off. I don't like the 3M Stuff. It works but it is has some serious fumes that gave me a headache and it seems really harsh to be putting on the paint. I will try Goo Gone when I do the doors. I cleaned everything up with some Meguiar's Ultimate Compound, by hand and then sealed it.
I will be debadging the doors, including the moldings. I am waiting untill I get my buffer to help with poillishing afterwards. There are a lot of swirls and small scratches on the truck that i would like to correct also.
I would like to get some new wheels. They will be chrome or at least shiny like chrome. No bigger than 18" simple design, with a little wider offset (+12 i think). with Duratracs or Silent Armors. I loved my Silent Armors in the past.
Thanks for the Comments and Compliments.
How did you do the front bowtie? paint? Or did u buy a black one from somewhere?
Just painted it. It doesn't look great if you get real close but it is fine.
looks good. I always like black. Good luck with your wheels decision.
I use a plastic putty knife on some of the larger badges. Works good and won't scratch.
I'm not crazy about getting new wheels. I like the stock ones just fine. Any wider and it will sling more stuff up the side which i deffinitly don't need. If I see something i LOVE, i might go after them.
To get rid of drips, I will take my truck back and forth between my two driveways, defore drying. That gets most of them out...the leaf blower is just another pain in the arse to drag out.
THanks
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 292 Guests (See full list)
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
