Covercraft Seat Covers
Anybody have pics of their covercraft seatcovers - Seatsavers. I've given the charcoal black a test drive at my local store, but I'd like to see how the flooded timer looks on a black interior. Or for that matter, how the other camo look. The online pics have been difficult to really see. Thanks.
I have seatsavers in charcoal in my 09 2500HD. Best seat covers I've ever seen, REALLY tough material, I'll snap a couple pictures this weekend and post them up for you.
