Help With Wheel Ofset
ryanneugebauer95
ok so im pretty new here and ive been thinking about buying new wheels and tires. Im not sure what offset to get and what tire size i will be able to fit. i have a leveling kit thats just waiting to be installed and i want to finally do it. i want to run 295/55/20 trail grapplers on some xd badlands. but like i said, i have no clue what offset to run. i know my stock gm 20s are +31mm offset so i was thinking +18 offset wheels. if some of you guys could help me out it'd be great. i tried to put a picture of my truck on here but it wont let me. its a 2007 sierra classic. 2wd
I think your right on the money, that should sit the tires pretty flush with the side of the truck. If you want them to poke out just a tad go with a +0 offset. Its not going to be obnoxious just give it a more aggressive look. From what i understand of the classic trucks, you shouldnt have a problem clearing the tires with either offset. I wouldnt go any less offset than 0 or anymore than 18
edit: I found this thread when I was attempting to help with another post.. I think it might be beneficial here too.
http://www.fullsizechevy.com/forum/general...-level-kit.html
If you look thru that thread theres a pic as you scroll down that will show you a shot ride down the side of the truck of 0 offset. They stick out probably about an inch, not enough to get you in trouble really.. BUT if you want them more flush, go with +18, they will literally be tucked in another 18mm.
IF you scroll down you will find the pic of a truck with +0 offset, and a tire approximately the same width as yours. It shows right down the side of the truck so you can see exactly how far they poke out. IF you think its too much, i would go with +18, they will literally be tucked in 18 more mm than the whats pictured.
