My Blazer
firecadet613
Well the rod bearings are bad, it has been diagnosed as the #2 cylinder's bearings.  I have an extended warrenty with a $100 deductable, so it shouldn't be to bad.  Except, they and the dealership want me to authorize a $400 teardown authorization in case the warrenty company rejects the claim.  I just got this Blazer on December 6th, I don't know what I'm going to do yet, if I sell it now I'm in the hole for about $1500-2000.  Anyone been in a situation like this before?  What did you do?
I was in pretty much the same situation last year when my 5.7 went tits up.
The Chevy Service Dept told me that they had to tear down the engine and the ext warranty guy had to look at it to cover it. I was told that if they rejected it, I was liable. I knew that I had done my part as far as maintenance and upkeep and I showed the service manager all my reciepts from oil changes, etc.
I told them to go for it and it worked out to my benefit.
If you have properly maintained the vehicle, I'd say you're okay.
You posted that you just bought this Blazer a little over a month ago. Did you buy it from a dealer and then get the extended warranty, or was it a private sale with the warranty in place? If it was a dealer sale, how much could you have abused the thing in one month (realistically)?
Sorry, I just reviewed your post in the Engine section. Can't your svc mgr tell you whether or not the busted oil line would be covered? That may be the key to the whole thing.
My engine was pulled a few hours ago.  It needs a new crankshaft and bearings.  Extended Warrenty company wants the pre delivery inspection report.  I've had the truck for 6 weeks, the warrenty came with it, there is no way they can deny this claim, right?
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 321 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
