Drivers Tire Spinning While Making A Left Turn
brandt4602@hotmail.com
Well today I was making a left turn out of a parking lot (barely pushing the gas) and the drivers tire was squealing the whole time so I stopped and made another left and it did it again drove about a mile and did a U-turn and nothing it all seems fine now
Do I have some issues? or is it nothing to worry about
the wife said it did that to her the other day
I’m pretty sure if the road was wet the truck would have turned sideways in the road
I got no lights on the dash when this happened nothing just tire squealing
I've had my lockers "locked" before without issue. If its unlocked now, then I'm sure your fine, but if not, a few backwards/forward movements should unlock it.
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
