How To go Look Up nPrice on GM Part
Go to PartZoneOnline.com (one of our Preferred Vendors  :thumb: ) and put that number into the space on the left side of the page, click enter, and it will tell you what the price is.  :cheers:
BTW,
12555685
Cap
List - $6.46
Core charge - $0.00
Your price (partzoneonline) - $4.45
Bill is a great guy to work with.  I ordered some stuff the other day and they got to my door in a timely fasion.  :cheers:
I can vouch for that as well, great prices, fair shipping costs and normally I'd get my stuff in as little as two days from when I ordered and 4 days at most.  Heck, I've gotten some stuff the next day when I ordered it in the morning.  Gotta commend him, he's the only online parts dealers that I would stand behind.
My I also suggest www.gmpartsdirect.com  They have smokin' prices on parts and they are also very reasonable when it comes to shipping and lead times of delivery.  That part you need is $3.87 there.  I have purchased many things for my truck there and have been very happy.  A friend of mine is a mechanic and does all that work and maint. on my truck and I am able to get parts from that site cheaper than what he can get them for.
But the shipping is $7.95 (which is their minimum S&H charge).  :cheers:  I think Bill will beat that.  I've checked on a few items, and none of them were more than $5.00.  These were all parts that were not particularly big, and cost under $50.00.
I've heard lots of people getting outragous S&H charges from GMPD.
I'll vouch for that, I used to order from GMPD until Jason Pendlum sent me Bill's way.  His prices were usually a few cents higher but you more than made up the money on shipping costs since he charged actual shipping.  Also, I found the service to be faster too.  Because of the great prices, shipping and service it's the reasons that I suggested to Zane that we get him on GM-Trucks.com as a preffered vendor since he is the best online parts dealer that I've found to date.  And still no one beats him.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 420 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
