A Selection Of Questions That Have Been Banging Around My Head..
2006 GMC 1500 5.3 Vortec / SLE
Can anyone give me a rundown to removing the rear pillars that the seatbelts are mounted to? I tried prying a bit on a few things and I just really don't want to start snapping clips off...
Any basic engine mods to increase fuel efficiency / Power? Reprogram, Tuning? If so where and who? xD
Best manufacturer for a box hardtop? I've been poking around and haven't really seen anything I've liked
Seats.. I really want to swap the seats for Leather, front and rear, It's an ext cab btw.. and I was also considering the center console swap, Ive been reading threads on this but I was hoping someone who has done it could fast track me, I'd love you long time.
Thanks for your time and consideration. Have a good one boys and girls.
Oh.. and where the funk can I get the specialty socket to remove the bolts on the front seat tracks? Every auto shop I've gone to around here just laughed at me.. le sighe..
I can't remember if the 06's have these or not, but if it's the star torx bolts you can get them at harbor freight if you have one near where you are.
external torx
If this isn't what you need just disregard.
Good luck
A tune/program would definately help with performance AND fuel milage.
Your location will help people recommend who to see about what :fart:
start with removing the door sills and then slowly start prying at the bottom...always peek to make sure you are applying pressure at the contact point and not a dead point
Blackbear Tune is the one I have installed in mine...completely worth it
To remove the front torx screws, pick up this socket: SC620B from Mac Tools
I completed the floor console swap:
http://www.gm-trucks.com/forums/index.php?showtopic=101227
My bad on forgetting to mention location..
I'm in Bradford, right between Newmarket and Barrie, but traveling isn't an issue. As long as the person I'm traveling to is "professional" about appointments and I don't sit waiting to even be seen for 3 hours. xD (Edit: Wow I'm a moron. I'm in Newmarket Ontario, Canada for all intents and purposes, I have a tendency to forget the fact that forums are attended by people from different countries.. heh)
Thanks for all the replies, reading through them now...
Another question.. The window control console on the front doors... I can pop the back clip out easily enough but whatever is holding the front closest to the sail panel will not let go, I've tried applying a fair amount of pressure in every way I can think of, any tips here?
Thanks for linking that Cueva.. Hrm, I guess I should've mentioned I have the manual 4x4 shiftbox right in the way of the full console, so that's a pipe dream but I'd still be interested in swapping the seats to Leather 40/20/40's and doing the rear as well.
Appreciate all the attention and replies this thread is getting, Making my life a little easier xD
that didnt stop one guy...he did the cutout on the floor console for his 4x4 floor shifter....
That front part is held in by a small screw (i think 7mm)...you gotta remove the door panel and unscrew it
Hahaha, a little further than I'm willing to go I can do without, I did have other plans for that space anyways, so not a big deal. I'll stick with that route and as for the window control panel; I have unscrewed everything and the panel won't come off and the guide I have says there's a screw hidden by said panel so I'm under the impression I have to remove it before getting the entire door skin off..
/shrug, Gona go back out and look again to make sure I didn't overlook something.
yep, there is one near the door edge that is hidden and the one near the hinge....there is one on the bottom surface as well. you have to pull up and out once all of the screws are removed.
When you say door edge and hinge.. Are those the ones with the little round covers? I tried popping one out but it held with quite a bit of pressure applied, I don't see any other bare bolts or screws.. blah
yes, near the door striker, you pry that cover off...the one near the hinge, you pull the entire "screw" out....
Thanks bud, figured it out a few minutes ago, the one near the hinge is one of the stupid plastic fasteners that GM is fond of that are rarely reuseable *headdesk* although they fared fairly well because I spent 20 minutes picking at them, and the one near the striker is just a T20 hidden by a llittle cap.
And you were right, the control assembly is fastened from the back by an 8mm socket, heh... Good thing I didn't pry too hard.
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • As a matter of amusement I’ll leave this conversation with this. Do you beat the government average fuel estimate? Statistics are a guide to me. Not a rule. Someone once said I have to have the last word. If true and possible may be. I’ll blame that on working in a family business.
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
