Amp For Doors
2009 Ext cab.
Door speakers: (4) Infinity Kappa 629.I
Amp in ?: Alpine MRP-F300
HeadUnit: Factory
Will this amp be enough to push the speakers and sound good?
The amp is 50x4 @ 4ohm, 75x4 @ 2ohm. The speakers are RMS 75watts each, Peak 225watts each.
If the amp is good enough, where is the best place to mount it? I've read behind the back seat, but will it get too hot there? External fan needed?
Also I've read about the turn signals being loud with a amp on the factory radio, is there a way to fix that?
2009 Ext cab.
HeadUnit: Factory
I heard about the turn signal thing too so I attached my line converter to the rear speakers since the turn signal "click" isn't played through the rear.
Does your truck have the full console?
Have you thought about the remote turn on for the amp?
The amp may be a little small but should be OK, To be sure I'd contact Crutchfield 1-800-955-9091 they sell Infinity.
