Hid's For An 01 Z71
I would really like to get some of these for my 01 Z71. Do they even make them for an 01? What are some good ones. Are the plug and play?
doesn't matter the type of car or anything ... its the bulb size.
Go to www.vvme.com and use the vehicle bulb size chart there and order the proper bulb size and ballast from them.
Not hard at all, mount the ballast somewhere and then the connections they give you are two spade ends you stick into your headlight socket. The best way is to buy a male headlight socket and use that, it makes it true plug and play and doesn't modify any stock wiring.
Hard to tell in your pic but it looks like you should do a headlight restore, even with the hid bulbs you wont get much light if they are foggy.
