1994 Sierra Idle Problem
hello i have a 1994 sierra when it i in park the rpm is at 800 and when it is put into drive the rpm go to 200 and it bogies when i do not give it lost of gas the idle air valve is working and can not find a vacuum leak. need help.
how about the plugs,wires,cap,rotor?go to the nearest junkyard pick pocket the map sensor,egr valve,tps,and take a gander at the injector spray.Check the fuel pressure to seems to be the cause of alot of problems.
