285/60-18 Nitto's
daxrizo
I'm looking to dump the stockers next week and was quoted for the above, what I believe to be, a great price. From what I can tell if I run the 285/65's I will rub and the tires above will lift the truck another inch, plus there's no need to re-calibrate the speedo and tranny. I'm not ready for a leveling kit or lift so your input is greatly appreciated.
Thanks.
Thanks. I guess I was too involved in research elsewhere and didn't use the search button.
i would like to see these tires on a truck without body leveling kit though.
well I got impulsive and couldn't wait so I went ahead and did it........pics without the front air dam and the above sized tires. Good thing is I don't have to re-program the speed and tranny.
Thanks. No rubbing whatsoever and the speedo is only off 0.3% faster so no reprogramming....cheapest way and it raised the truck an inch. when these tires go bye bye I'll upgrade to 305's with a lift but for now they look beefy.
Thanks.
what exactly would you have to re-cailbrate in the transmission exactly?
the 285's I had on my last Z71 changed the speedo and shift points. I had to reset the tranny shift points as well or it felt like I was dragging a parachute around. The previous tires were 286/65's and these are 60's, no issue so far
Im running that size in toyos (same manufacturer). I couldn't have fit them without a leveling kit, but that is due to the aftermarket wheels.
Thanks.
ohhhhh, well i was like WTF are you guys talking about. I have a blackbear tune coming which should take care of that problem :lol:
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
