2010 Non Bose
My buddy is trying to hook up and amp and sub to his stock stereo(head unit). We have the in line converter from best buy. We are having trouble figuring out which wire to connect the remote wire from the amp to. We know the red wire provides power all the time and the black wire is the ground. Which wire out of the harness's plugged into the head unit do you connect the remote wire. I may not being explaining things fully so if any additional info is required please let me know. Thanks for the help!!
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 323 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
