Torque Specs for Spark Plugs
Does anyone know how tightly you should torque spark plugs in an 8.1L?  I want to change mine now that I put Top End Cleaner in it, and I can't find a spec anywhere.
Thanks-Fitz
The old torque spec. was 15 ft. lbs. in the cast iron heads with the taper seat type sparkplugs.  I don't know the spec. for the aluminum heads.  I would assume it will be less than the cast iron.
2002 Silverado/Sierra Service Manual
Spark Plug Fastener Tightening Specifications
8.1 15lb ft
4.8/5.3/6.0 11lb ft
4.3 new heads 22lb ft
    used heads 11lb ft
Not to preach, but if anyone wants to do more than an oil change on their truck, they should invest in a service manual set.  Helm Inc.  5 manual set (2002 anyways) $120 part number GMT02CK8PU
8.1 15lb ft
4.8/5.3/6.0 11lb ft
    used heads 11lb ft
Better yet, get it on CD rom.
Or you could always just screw them in hands tightness and then throw a 1/4 turn on it with a socket......it's just a spark plug.
    mighty K20
    mighty K20
  • Who's Online   4 Members, 1 Anonymous, 651 Guests (See full list)
