bigjim1961 Posted March 28, 2011 Posted March 28, 2011 Replaced cluster with new and replaced speed sensor on transfer case and speedometer still wont work all gauges working , and odometer will not work
Stevens03 Posted March 28, 2011 Posted March 28, 2011 Welcome and ouch! Did you check all the fuses? (inside and under the hood)
bigjim1961 Posted March 28, 2011 Author Posted March 28, 2011 Will try that Welcome and ouch! Did you check all the fuses? (inside and under the hood)
bigjim1961 Posted March 28, 2011 Author Posted March 28, 2011 all fuses checked good maybe wire problem seen a mouse nest under fuse box under hood Will try thatWelcome and ouch! Did you check all the fuses? (inside and under the hood)
bigjim1961 Posted March 28, 2011 Author Posted March 28, 2011 its about to reach my limits chevy dealer installed cluster , i put the sensor in may need to go back to dealer Gonna have to start digging deeper.
bigjim1961 Posted March 28, 2011 Author Posted March 28, 2011 The tech had it hooked up to a computer doing something to it all they did was replaced cluster under waranty and he said he cleared codes but did not remember what they where also service airbag light comes on it was doing that before going into shop , before going to shop only gauges working was gas , trans temp , tach. is there a way to test wires going to speed sensor on ohms or voltage they programed it right????
Stevens03 Posted March 28, 2011 Posted March 28, 2011 Your still under warranty, or just the cluster. And if so, why did they give it back to you not working?
bigjim1961 Posted March 28, 2011 Author Posted March 28, 2011 2005 3500 4x4 67,627 miles it was just the cluster i guess they did it on a goodwill standing, it did not work when i left , i figured it would be the sensor Your still under warranty, or just the cluster. And if so, why did they give it back to you not working?
