Brooklyn,ny
jimbro
Regular at Chevytalk followed link on a topic and liked what i saw so here I am.
99 K1500
Work done by me....
Intake gaskets
2 Exhausts(Flowmaster, Gibson)
Alternator(2)
Stillen/K&N intake
Wiper motor
Pads and rotors..lost count
Plugs, wires, dist.
Fuel filter
    Brendan C
    Brendan C
  • Who's Online   4 Members, 1 Anonymous, 1,163 Guests (See full list)
