Sierra Starting Issue
Guys, I am in need of opinions. Ive got a 99 Sierra with the 5.3l The last few weeks I have had a problem that is getting worse. Used to be after the truck had set for awhile, it wouldnt fire on the first key turn. It would turn over but not fire as if it had no gas. It would almost always fire right up on the 2nd key turn. Now its getting to be the 3rd key turn before it starts. Once started its fine. Im wondering about the fuel pressure regulator possibly going bad. Spark plugs and wires are new. No smell of gas ever. All opinions greatly appreciated.
Fuel pressure comes to mind first. Dumb question but have you changed the fuel filter lately?
Have you tried turning the key to the run position for 1-2 seconds, then hitting the kit to the start position and if so, did you see any change?
Steve, I havent changed the filter lately. I havent tried doing the key the way you said. I will try that and see what happens. Are you thinking fuel pump with the pressure issue or the regulator? If anyone knows what size the flare nut is on the fuel lines to the filter, please let me know. Thanks
Regulator :seeya: But I'm no expert... but that what it sounds like to me.
Steve,
Ive tried doing what you said with the turning the key over for a few seconds and then going to the start position. Seems better that way but the 2nd attempt wasnt as smooth as the first time I tried it. I waited about an hour in between attempts
Pull the vacuum hose off the regulator, if gas comes out or it is wet, replace the fuel pressure regulator.
will do when I get home from work. I dont think its the regulator based upon symptoms I have been reading. Will letyou guys know if its leaking
didnt see any gas when I pulled the vac line. What I have figured out is that if I turn the key and wait about 4-5 seconds, then turn it all the way, its starts pretty much the first time.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
