305/70 R18
asvinci
Depends on wheels.
I've got the MT 305/70/18 on a 4.75 back space wheel and I rubbed a good bit.
Had to cut plastic in front of tire and bang metal in the rear (front tires)
If you have a positive offset tire you will have less to trim but probably will need to trim a little also.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
