Rear Speakers And Baffles
Bought a set of Infinity reference speakers from crutchfield. Components for the front and the 4x6 speakers for the back. They also recommended I use base blockers on the 4x6 rear door speakers which I know are a must with such a small speaker but they also gave me those foam baffles that they say are there to keep the moisture off of them. But I was thinking about those baffles and I am thinking that they will kill any kind of midrange that the speaker would produce. They really restrict the air movement behind the speaker. What do you guys think. Are they worth putting them in or should I just leave them out?
Depends, if you're expecting decent bass out of your door speakers, put em' in. If you just want your door speakers for mid range and highs, then it'll be just fine to leave them out.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 510 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
