Alternator Noise
My alternator starting making noise this weekend and it sounds like bearing squeal. The truck is an '02 Yukon Denali, 6.0L with 144k miles and the original 130amp altnernator. I replaced both belts 3 mos. ago and I'm pretty sure the noise is not from the belts. I'm still showing normal charge. If this is a bearing in the altnernator, what is the likely part which is failing (pully bearing?) and can it be repaired vs. replacing the entire unit?
be absolutely sure it is the alternator and not the power steering pump or a pulley. I thought it was my alternator that was making the noise and so I replaced it. New one in, and the same noise was there. Wasted $200 because I did not diagnose it right. (The screwdriver to the ear thing does not work on things like this)
If it is the alternator, it is a piece of cake to replace!
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 565 Guests (See full list)
