Fs Dl3's And Dl8's Gmt900 '07 And Up
I have for sale a set of DL3 mirors with white caps in good cond but no puddle lights on them
also I have a set of DL8 mirrors that I removed from my own truck @ 36k when upgraded to DL3's
look at the pics and choose your mirrors and your color caps
asking $300 for the DL3's and $150 for the DL8's plus shipping
  • 3 weeks later...
bump
I'm willing to negotiate
I know it's a long shot but willing to split up the dl3's? I'd like to complete my set and I trashed the passengers side.
Are the DL3's plug and play for the signal lights?
A quick and easy way to tell if your truck is wired for DL3's is to remove the the fuse panel cover at the drivers side, look at the fuse panel. The upper left connector goes to the door, it should be Lt gray.If you want to check for turns, which most vehicles are wired for, same connector, pin b2, bottom row, six from left or two from right, wire is lt. blue w/white stripe credit to --->fsrtwo
sorry guys the DL3's are SOLD SOLD SOLD
bump for the DL8's
pm replied
edit: I was told that if you have the luxury package you can have DL3's but you still have to change the switches
but if you don't have that like me, (I have the LT1) then most likely the turn signals are plug and play if you have power mirrors!
What I'm doing is this, I installed the DL3 mirrors and besides the normal power all I have is the turn signals
when I got the switches I found that the harness that I have don't fit the plugs in the switches, but I was told by "montyss" that with a new harness for a truck with luxury package I will be able to accomplish what I want, 'cause that's exactly what he did in his single cab!!!
I'm in the proses of ordering the new harness and as soon as I get it I will install it and hopefully everything will work like is supposed to
I will let you know what happens then
