I am having the CEL for a while now. P0455
I have replaced the gas cap with a stant one. I have checked the valve in the manifold and it is operational when 12 vdc is applied to it.
The question is:
Will the vapor Canister Solenoid (Ac delco 2142149) from a 2004 sierra work on a 2003 sierra. I am not planning on relocating it just replacing it.
...Will the vapor Canister Solenoid (Ac delco 2142149) from a 2004 sierra work on a 2003 sierra...
If the electrical connector / plug matches, it should work.
Suggest you remove existing unit, blow out and bench test to confirm it's malfunctioning.
    overspeed
    overspeed
  • Who's Online   3 Members, 0 Anonymous, 157 Guests (See full list)
