Intake Gasket, Best One?
Did a search but came up empty. About 2 years ago I was getting coolant in the oil on my 1996 K 1500 with the 5.7. I did not have time to fix it then, so I put THIS STUFF in it. It has held up pretty well, but now I'm losing coolant again with no visible outside leak. I'm losing about a pint every two hundred miles or so but I'm not seeing anything in the oil this time. I'm thinking I need to change out the intake gasket but I want to get the very best one that is available, as I don't want to be doing this again anytime soon. Anybody got the brand and part # of the top-of-the-line "fixer" gasket set?
I went ahead and got the one from Advance Auto that I put in the above link in post #3. It's got the whole set, including the one for the upper plastic section. Anybody have any tips or shortcuts that I should know about before tackling this? Torque values for the manifold bolts? Thanks.
I've got a 1997 5.7L Z71, same problem, kept getting worse. I used the Felpro kit also, the instructions said to apply dry, many techs said to use silicone or I'd be doing it again. I probably voided the waranty because I used silicone. 6 months and 5000 miles later, tight as a drum, no leaks.
Warning: on the passanger side near the front, there is a heater hose connector ( pot metal ), it will look like crap, the o-ring and plastic locking mechanism will probably fall apart when you disconnect it. The auto parts stores will try to sell you a complete replacement kit, do not, repeat, do not try to unscrew it, the mofo will break off, go to the dealer and get the correct o-ring and locking mechanism. Guess how I know, was the worse part of the whole proceedure.
Good Luck
  • 3 weeks later...
If you go to the dealer or buy from any of the online GM parts sellers, the replacement GM gasket set is updated/superseded with a new style gasket that is as good, if not better than any aftermarket. It should be P/N 89017465
this is the first time that I have heard of this ... and considering the fact that GM let this issue go on for such a long time ... I would just by-pass the GM gasket, and get the newest version of the FELPro gasket that is available for the Vortec engine ... don't take a chance on the GM gasket when you KNOW that the FelPro will do the job and be the reliable fix .. the first time.
    overspeed
    overspeed
  • Who's Online   1 Member, 0 Anonymous, 326 Guests (See full list)
