Carquest Blue Ceramic Pads
I was kind of disappointed that the Carquest Blue Ceramic pads that I picked up today for my truck's rear end were made in India. I guess I should have expected that these days. I wish C and A's Dad (Rest in Peace) was here to calm my concerns.
I haven't gotten a good part from CarQuest in a LOOOOOOONG time. They've gone way cheap. I actually just bought my LAST part from them, an alternator which is crap. Made in Taiwan.
I bet you'll have a tough time finding made in US brake pads/shoes. Those are some nasty chemicals they use and I'd bet it's easier to do in less developed countries with looser environmental regulations.
My wife's '09 Buick has a Denso (made in Japan) factory alternator. Popped the hood on my '11 Silverado and can't find a marking, but the case sure looks similar. Face it, a lot of OEM parts are not made in North America, which can mean the USA, Canada or Mexico.
    Sothpaw27
    Sothpaw27
  • Who's Online   3 Members, 0 Anonymous, 700 Guests (See full list)
