Flowmaster 40 Series. Gmc 5.3l
GunMetalGM
Will add sound but little to nothing performance wise.Flowmaster does the exact opposite of its name.
Well, I've had the 30, 50 then 40 and wasn't happy with any of them. They rust to fast, and they drone alot, epecially when towing. My experiance was with a dual rear exit and on my 03 5.3, I lost low end torque. Just not enough back pressure. It won't hurt anything, and will sound good outside, but it will drone and if you use a dual exit, you'll loose some low end torque. :flag:
x2 to all the above answers, FM is known as a cheap easy way to add some sound to your truck. they are also known to rust really fast. if you want performance i would go with a borla or a magnaflow. they are more expensive but worth it in the long run.
