Proper Way To Wash Your Vehicle?
oldschool327
[url="http://www.youtube.com/watch?v=FI7BHSOVtMs&feature=player_embedded"]Proper car wash[/url]
Liebherr R-9800 and water is 62.5 pounds per CF that is 92,643.75 pounds of water droping on that car
I work for a water utility and we do a system wide flushing twice a year where we flow our fire hydrants up to 2,000 gallons per minute. We use a diffuser on the hydrants to spread the flow out so as not to mess up the roads or grass when we do this. A couple years ago we were flushing when I saw a teenager in a Chrysler of some type with a sun roof in it, he and his girl friend went around the block a couple of times the other guy with me said "I bet he drives under the water" and I said "no way is he that dumb" but boy was I wrong he started to pull under the water very slowly when I saw his girl fiends hand go up out the sun roof to feel the water spray, and you can guess it he drove under the water with the sun roof open hydrant was running about 1,000 gallons a minute, when they got out from under the water and opened the doors water was up to the seat bottoms. I think he was madder at us for laughing at him than he was for ruining his dads car. :dunno:
  • 1 month later...
  • 1 month later...
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 713 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
