Stability Control ?
My ABS light and T/C light keep going on constantly. Brakes look good. Would a wheel sensor or something be causing this? Also heard like a scraping or dragging sound in right front wheel, Not there all the time. If it is the sensor can i replace it my self ? 2004 Yukon. Thanks Bob
Possible left front hub bearing causing an incosistant and inaccurate left front wheel speed sensor reading. Check the left front hub bearing and see if its loose.
Thanks for the reply. I actually pulled right hub assembly before i read reply. That was the problem, Loose bearing. All is well now. thanks Bob
you will need a code reader then Check wheel speed sensors -
then ABS Fuse, also power connection at ABS Module
    Selfman
    Selfman
  • Who's Online   5 Members, 0 Anonymous, 643 Guests (See full list)
