Blower Motor
cardr69
I have a 2003 Silverado and blower does not work on any speeds, I already replace resistor and wiring, I have power at the motor but still does not work, worked fine one day then the next not, any help would be great.
Are the motor leads measuring 'open' or in the megaOhm range? It might be you opened a winding or your brushes have an issue.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
