Air Bag Sensor Location (s)
My service air bag light is on with message. Dealer repaired last year for about 250.00. Is there more than one? Where are they located?
There are dozens of things that can set the airbag light to come on. There should be 2 sensors up front, maybe one in the airbag controller itself as well (not sure if GM does that) along with a ton of connectors and other bits that can cause the light to come on.
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 501 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
