Silverado Usb Will Not Recognize My Thunderbolt!
Do you guys have any idea how to get my 2011 silverados usb port to recognize my HTC thunderbolt? I plug it in and it says unable to recognize this device
I have downloaded dual mount...that people said would work with no luck!!
Help please lol...
Is the phone set to transfer as a USB mass storage device when you plug it in? What music file types are on it?
They are Mp3s.... I have changed it from disk drive setting to a music sync...turned my debugging on and off...still with no luck.
i read somewhere in a thread that you have to format the drive with FAT32 and that will solve the problem, but then you have to put all your tunes back on the device.
Can you explain this a little bit more or do you have a link? I'm not sure how to go about doing this.
search is my friend...would you like to meet him too? LOL...j/k
http://www.gm-trucks.com/forums/index.php?...l=usb&st=15
USB-Supported File and Folder Structure
The radio supports:
• Up to 700 folders
• Up to eight folders in depth
• Up to 65,535 files.
• Folder and file names up to 64 bytes
• Files with an .mp3 or .wma file extension
• AAC files stored on an iPod
• FAT16
• FAT32
FYI.
The radio supports:
• Up to 700 folders
• FAT16
• FAT32
FYI.
I dont think I'm very smart lol.....Still does not work after formating my audio file on my thunderbolt.... Thanks for all your help...I will continue to work on this.
The radio supports:
• Up to 700 folders
• FAT16
• FAT32
FYI.
I believe you have to format your SD card. That is where the music is usually stored. You will probably have to copy all the info on your card to a folder in your computer, format the SD card to FAT32, and then send all the information back to your SD card. I hope that works for you. Before you format your SD card, try it on another card. That way if it doesn't work, you don't have to worry about deleting stuff on your main SD card.
The radio supports:
• Up to 700 folders
• FAT16
• FAT32
FYI.
that's how i understood it, as well, but couldn't seem to put that thought out in writing...lol.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 508 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
