Recently we just went through a hail storm where I live, and my truck has 4 quarter to silver dollar size dents in it. Anyone know any tricks on how I could pop these out? They didn't scratch the paint.
please help
About a year ago, my 06 was hit hard by hail. Over 200 dents removed by the paint-less dent repair guy. No visible marks on the truck after the repair. The bill was like $2,400, but my comprehensive insurance picked it up, less the $250 deductible.
If you search 'paintless dent repair' on you-tube, it shows some videos on how they do it, but if there was a bad hail storm in your area, the body shops will have the service available. I believe the guy who did mine travels around following the storms.
