How To Change The Lightbulb In The Side Door Of A 2500hd Truck (2005 I
liljepp
Today my father dislodged the lightbulb in the passenger side door of his 2500HD truck while changing the side mirror. Is there anyway he can get to the lightbulb and replace it without having to go to a dealership?
TIA
4 threads on the same topic? is that really necessary?
and a picture is probably going to be helpful for those of us that don't exactly know what you are referring too.. but I presume you mean the red security light in the lower corner of the panel, and you should be able to pop the plastic cover off and reach in and fish the bulb out.
if you look at the lens, it will have a small notch in it, using a small flat blade screw driver you should be able to GENTLY push in and pop the lens out.
Thanks. We'll give it a try.
I didn't mean to have 4 posts. After I tried to submit, it said there was an error. I didn't think to check to see if it had gone through anyways and should have. If I could have deleted the other posts I would have.
Thanks again for the idea.
Oh that makes sense. Sometimes people post multiple threads to fill the new posts page in hopes of getting a faster answer.
Hope you figure it out. (The light I mean)
