Alignment Results Review
Plainsman
Hello, after being stuck this winter several times I have new skins. New BFG all terrains. 265/75/16s.
I put on the new tires and my right hub was shot so I replaced that, then had the alignment checked. They said the toe was off so I have new results.
However the truck seems to wander more than I recall, but it could be the new tires or fixed hub. According to the tech and the report the toe was fairly off. He also stated the ride height was close but its good now. I belive this alignment tech is very skilled. Do these number indicate I need the alignment touched up a bit to make it less responsive/heavier? If the numbers look good Ill let it rest and put on some more miles. I probably only have 400-500 miles on the new tires, hub, alignment. Curious the opinion of some experts here.
Thanks
Previous Alignment
Left Right
Camber .5 1.0
Caster 3.2 3.6
Toe .34 .22
Steer Ahead .28
New
Left Right
Camber .4 .2
Caster 3.2 3.5
Toe .05 .04
Steer Ahead .00
Those are just about dead on. Depends on the year of truck. The 07+ (newest body style) seem to wander more than the older ones. If I recall the older ones want .20 total toe and the 07+ want .10 total toe. You should be ok.
Good enough then. Mine is a 2003 1500HD 72,000 miles. Ill just see if I can get used to it. Guess just used to driving on chewed up tires and a bad hub :thumbs:
