Innova 3160
Has anyone have expereince with Innova code scanners/readers ? I was looking around for an easy to operate but solid unit to do diagnostics with. Something that doesn't require a degree in electrical engineering to operate. I came across the Innova 3160 which is their top of the line unit. It lists for about $450 on their site but can be had for under $200 on the WEB. The only drawback is that from what I can see the function that clears the "check engine" light clears all codes at once instead of just one at a time. This may or may not be important to some.
Any feedback ?
Thanks,
Fred
It's a good unit and also has ABS capabilities for some US vehicles. If i was buying a handheld today it would be that one.
I've used it because a guy at work bought it on my recommendation, and i've borrowed it to check out a few ABS codes. I currently have an Actron and would recommend the Innova 3160.
Matt,
I work w/a bunch or real motorheads and a couple have had experience w/the Innova, both ended up returning them due to they're not compatible w/all ABS systems, plus there's a known defect in the software (and Innova continues to sell the unit knowing this ?). The general opinion is to look at the Actron units which are a bit more pricey but have a better reputation. Have to do some more checking before I take the plunge.
Fred
I bought one at Sears a year or two ago, can't remember the brand...But it's helped me (and several other people) out many times. I paid less than $200
I seem to recall it being able to read ABS stuff, but I could be mistaken. HOWEVER...I've not once in my life had a need to read/clear ABS codes. If I did, I would just swing by AutoZone, as they'll read/clear them for free anyway.
Matt,
Fred
theres a list of vehicles the ABS is compatible with; and it clearly states it not compatible with every make/model, thats why they provide a list. fwiw its worked for every one ive needed it for.
whats the software defect about? i didnt have any issues....
  • 4 weeks later...
Any feedback ?
Thanks,
Fred
[/quote
I'm new on here but i bought a innova can obd2 reader from costco for 50.00 and it read the codes on my 04 gmc sierra and cleared them it also tells if you'll pass emissions and has a dick that will tell you what and where the problem is in the motor with an exploded view of the problem, its worked and payed for itself already.
Just used the Innova to solve an ABS issues on a Chevy Blazer this week. Worked flawlessly again.
Still curious what the horrible "software defect" is? I tried google searching and couldn't find any "well known defects"...
Seems to me the only [somewhat] common issue is people not paying attention and blindly buying it for the ABS, and then when it doesn't work they realize their vehicle is not on the list. All you have to do is go to the Equus website they have a link right on the product page to figure this out: http://www.equus.com/Content/Support/Downl...50-3160_ABS.pdf
    ar0517
    ar0517
  • Who's Online   3 Members, 0 Anonymous, 761 Guests (See full list)
