Transmission Problem
so a couple of days ago i went to turn on my truck to go to work and everything was fine till i put it in DRIVE it just revved so i put it back on PARK and then to DRIVE same thing happened it just revved so i put it on FIRST just to put it back on the driveway and left it there. when i came back from work i started to mess with it and found out my DRIVE and THIRD gear werent working, everytime i switched toi those gears it made a scratching noise and would just rev, every other gear works. any suiggestions in what could be wrong and what i need to do to get it fix????? thanks in advance
Get a 12 pack and some buddies and your tool box,jacks etc and start pulling the trans out.or take to a shop
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,164 Guests (See full list)
