Drive Train Noise
I have a "99 Tahoe & an "08 Tahoe and they both have the same noise that is related to the the drive train I think. When I have to stop hard at a red light and take off again there is a noise that sounds like a clunk or a thump when I release the brake and then accelerate. Would someone please tell me what GM's position is on this noise and if it there are any serious problems from this condition.
Thanks,
walex
almost 100% sure your experiencing the slip yoke clunk...it is not harmful just more like annoying...you can remedy it by packing the slip yoke with i believe heavy grease on 2wd and tranny fluid on 4x4?
i have the clunk and just live with it...
Thanks for the input. I found an article in a truck magazine that calls it Drive Train Backlash. The article also indicates that there is no need for concern & that spending a lot of money to fix it is pointless. If anyone has a TSB from GM on this I would appreciate a post on the info or where to find it.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
