Anyone use this place ? Preformance Brakes
I haven't used them...
Check out Brakeamotive on E-bay...$177.00 ish delivered. Slotted and cross drilled rotors and Ceramic pads..I installed mine a few weeks ago...Huge difference over stock..
Thanks Bob
Thanks Bob
Just put a Brakemotive setup on the wife's Trailblazer, $190 for all 4 wheels and got them in like 2 days. Highly recommend, make sure to follow the break in procedure.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,032 Guests (See full list)
