Fs: 2007 Trailblazer Ss
2007 TBSS AWD 1SS, rear dvd, have headphones and remote. Truck has 53K on it but is my DD and will slowly go up. I bought it from the dealer who originally sold it.
Im second owner, original owner was a member on another SS site and a person from there hooked me up with him so i could get info on this SS. Well maintained, never raced, not modded other than exhaust is a magnaflow muffler with not res. 4" tip. Tinted tails, reflectors, and 3rd brake light done by UR50SLO ( TBSSOWNERS.COM)
6.0L V8 - 390hp+
265/55/20 General Grabber UHP tires are wider than stock
It is a great vehilce but I will be doing a ton of driving and do not want to rack up miles on her. I would like to sell her as fast as possible to avoid miles going up in the process of selling. I am only looking to get what I owe. However I will list it at $20,000 obo. I owe a little less than that.
KBB on it is $24-25K, NADA is close to $27K
This is a great deal for someone. You can mod it however you want, you can drive it daily. Its good in all weather.
PM ME if interested.
TTT...
Need to sell by end of August. Willing to deliver up to 8 hr drive. Only want to break even on $$.
This is a nice vehicle and i dont want to beat her to death on the highway for work when i start travelling.
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 491 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
