Driver Information Center
I'd like to install a driver information center in my '02 sierra 2500hd cc but don't want to spend thousands of dollars on a denali center console.  i've seen them in blazer overhead consoles before.  Is there any way to purchase one for my overhead console?  Homelink would be nice too.
Welcome to the forum.  I know JP Customs (see his link in the left column of this page) sells the HomeLink that can be installed in your truck.  As far as the computer information center, send him an email.  If anyone can do it or figure it out, then he would be the guy...
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
