Hdtv Digital Antennas
Mossyoakglock
Hey Guys,
Since cable and sat TV are so expensive around here we are looking into the idea of getting a TV antenna for the house. I've looked at Best Buy and they have a couple indoor antennas from ClearStream that are under $100 that seem pretty good. Most seem to have a 35 mile range as well. While we like the additional channels, as long as we have the basic local channels (ABC, NBC, CBS and FOX) for news we are ok. When football season gets here these are they channels the games are usually on too. We have internet for anything else we might want to watch.
Are these antennas any good? Will the channels be in HD? I have never seen or used one of the new antennas so this is all new to me. If anything we'll just buy it and try it out for a week and then return it if we don't like it.
We are just trying to find ways to save some money while the wife is finishing up her degree.
i used to use a $40 in-door Philips HD antenna and it worked very well, at least in my area. at the time over-the-air HD picture quality was considered superior to cable and sat HD, it was the cleanest way to transmit an HD signal. not sure if that's the case these days but even so i don't think you'll be unhappy with the picture quality. one major annoyance is that the signal can still become interrupted (like any OTA signal) and instead of 'snow' or 'static' you get image pixelation or complete image loss. this site will help you locate the antennas in your area: http://www.antennaweb.org/aw/welcome.aspx
I use the HD ant. also, It looks like a small book that you can hang up or stand, it has some 360deg. range or somethin of the sort so the signal doesnt fade and can always search for the best signal.
I got this one from Radio Shack,
http://www.radioshack.com/product/index.js...oductId=3912573
after going thru several of the crappy ones at best buy and never being able to grab all the channels without moving the damn thing for 10 minutes and standing on my head.
That one works wonderfully, plus has a remote to rotate the internal amplified antenna so once you have it set you don't have to do much except rotate the internal antenna or raise/lower the gain control.
The only other issue we have is being in the direct flight path for LAX and every 15 minutes as a plane takes off the signal drops for a few seconds as the plane passes overhead, and NOTHING can fix that, roof mounted antenna, DirecTV, Dish Network, nothing, they all have issues with the damn planes blocking line of site..
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 765 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
