Custom Bowtie's Frt&rr
I am looking for a custom paint job on a set of Bowtie's,for a 2011 HD Chevy Silverado.I saw one emblem for a classic and it was painted silver with a diamond plated look.Does any one know of custom bowtie's for sell ?
buy the sticker overlays off ebay
I bought a blk billet powdercoated front bowtie from chevymall.com. I got the tailgate bowtie vinyl wrapped at a local tint shop. I tried to do the vinyl wrap myself on the tailgate bowtie but it was hard and looked like crap(too many bubbles). Leave it to the pros if you have no experience with vinyl.
Thanks guys I check it out,it was a medium silver diamond plated bowtie look real nice job,I think it was a airbrush job.
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
