Spent about 8 hours detailing the truck this weekend, rubbed out with meguiars ultimate compound with just a random orbital and yes it took about 8 passes per panel to get it swirl free and there are still some scratches, but a whole heck of a lot less. then topped it off with 2 coats of Z5 and a coat of Z2 on friday. ZCS on saturday and let it cure all day and night while i did the windows and steam cleaned the interior. this morning hit it with grand finale spray Z8, let that cure then topped it off with turtle wax black detail spray. its not of a good as a write up(or job for that matter) as dylan but it came out to a swirl free finish, then the black detail spray to help hide a few of the bigger scratches i couldnt get out. more pictures later!
side note: i put tire shine on the weather stripping because i read siliconing it will help with creaks and WOW did that help out big time. it took 2-3 coats cause the stripping was so dry it absorbed it all. but what a difference.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
