2006 Sierra Tranny Slipping....
dasher_98
hey guys, good website here was reading up on similar topics with loads of input and info but i still dont think i found the answer. my truck a 2006 gmc 4x4 sierra with 90,000 kms, 4.3L, automatic trans with a new tranny oil change about 1k ago (at a certified shop) has been great to me since i bought it until today. i was climbing a hill when D grave out (not bagging it). i tried 3rd same thing, the egine revs up and nothing like its in nutureal. but 2nd and 1st will still engage and 3rd and D will work after doing 60km+. after playing around with it, it will slip out of 2nd, 3rd and D while under sudden 1/2-3/4 ish throttle without makeing any nasty noises at low speed..... i watched to see if any driveshafts were moving and none were, which makes me believe its the tranny. my oil level is a bit high but i don't think that would have an effect plus the oil dude at shop told me its good plus i read on here that gm recommended add 1/2 q more.it will engage into 1st, 2nd sometimes 3rd and D (this just happened today so it might vary). so what do you guys think? i would a appreciate any advice over comments or tips as this truck must be dependable becuase of work and hunting season coming up.
thanks, ty
regina, saskachewan
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
