Help! 2005 Gmc Sierra 1500 5.3l
Ok I need some help I have a 2005 GMC Sierra 1500 w/5.3L. My problem is that it smokes at start up after sitting for some time. I changed the valve seals and it was good for one whole day. Then today after starting in the am and driving to work and sitting for a while I went to lunch and There was SMOKE!! Coolant level is fine. It was burning about a quart of oil every 2 - 3 weeks.
Everyone I taked to said valve seals. It only smoke when started and thats it. It will foul plugs avter a while because of oil of course but I dont know what to do next.
Any help would be appreciated.
Mileage on vehicle is 166,000
Thanks
Randy
From what your describing it sounds like the text book definition of valve seals...BUT if you have luck like me your problems are never text book problems. When you drive and your cruising at say 50+mph....drop it from 4th to 3rd and let off the gas so the motor slows you down. When you do this does it smoke? (make sure it makes your RPMS go pretty high so it creates a lot of vacuum). Also go from a slow speed and jump on it. Does it smoke while your wide open?
Man, you know thats the first time in a long time I've heard anyone having that problem on this forum. We might all be too anal about maintenance to have valve seal problems. Has your vehicle ever overheated rather majorly?
When I down Shift it does not smoke however if I punch it it will smoke grey or dark color smoke. When sitting and started it will smke white to light grey smoke. The truck has never over heated. and I maintain it like no tomorrow. Oil changes like clock work sensors changed and so on.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
