Emissions Warranty Question
I have 41,000 miles on my 2008 1500 silverado with a 5.3 non flex fuel. its throwing a code for an emissions control solenoid. will this fall under warranty for the emissions or should i just be doing this myself? Thanks.
ken
ken
I would think so, but you can just punt a call to your dealership to confirm. Saves the trip down there...
ken
yea ill have to give them a call tuesday.
That will be covered 100% under the emissions warranty. It's all covered in the Silverado Limited Warranty booklet.
I did read through that but wasnt sure. It kind of circles around alot on whats covered and whats not.
Did your warranty end up covering it? I am having a similar issue...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
