Movie Rating
RyanbabZ71
Pretty good movie.  If you have seen the 1st 2 then you will wanna see this one.
Id say 7.9 out of 10
:popcorn:
good one.  I wondered what that popcorn was for.
I was going to use that one for cool threads where people are arguing.  Just grab the popcorn and sit back and read :puke:
But, I'm gonna have to see that.  I saw the first two and they were pretty funny.
    Dom Colussi
    Dom Colussi
  • Who's Online   3 Members, 0 Anonymous, 665 Guests (See full list)
